Creating and Downloading .png Images from Slideshows for Art Canvas+
Many VEXcode VR Activities that use the Art Canvas+ Playground provide images via a Google Slides presentation. This article will cover how set up a presentation to use the optimal dimensions for the Art Canvas+ Playground and how to download those images as a .png file.
VEXcode VR project with a slideshow used to create a PNG for Art Canvas+
Creating a Custom Image in a Google Slides Presentation
VEXcode VR start screen with Playground and coding mode options for opening a project slideshow
To create your own custom images for the Art Canvas+ Playground with Google Slides, open a new presentation.
VEXcode VR block workspace with the Art Canvas blocks used to create a slideshow image
The optimal image size for the Art Canvas+ Playground is 1000 pixels by 1000 pixels. To change the layout of each slide to match that size, begin by selecting the "File" and then "Page Setup."
VEXcode VR block-based workspace with a Tutorials panel for creating slideshow images for Art Canvas+
Open the dropdown in the Page Setup menu and select "Custom."
VEXcode VR Tutorials section with a block-based project open for creating slideshow images
Change the units to "pixels" using the far left dropdown.
VEXcode VR interface showing the block workspace and controls used to create a slideshow image for Art Canvas+
Then insert "1000" by "1000" for the size and select "Apply."
VEXcode VR block workspace with Art Canvas project blocks for creating slideshow PNG images
Each slide will now appear as a 1000 pixel by 1000 pixel square.
VEXcode VR block workspace with the Art Canvas project open for creating slideshow PNG images
Now that the slides are set up, you can modify and create your own uploads for Art Canvas+. This example shows a unit circle, topographic map, and a word search that could all be uploaded to the Playground.
Watch this screen recording to see the above steps.
Downloading Images as .png Files from a Presentation
To download an image from a Google Slides presentation, select the File menu and then hover over the "Download" option.
Slideshow menu with Download as PNG selected
A menu will expand to show the various download options for the presentation. Select the "PNG Image (.png image, current slide)" option.
Art Canvas slideshow menu with the option to download the current slide as a PNG file
This will download the slide you are currently viewing as a .png file to your device. The file will be named after the name of your presentation.
Note: This image shows a download on Mac in a Chrome browser. The download location may be different depending on your device and chosen browser.
Note that you do NOT need edit access to a presentation in order to download a slide as a .png file. The option will still appear in a View only document as shown in the video here.
To learn more about how to upload an image to the Art Canvas +, see this article.
