Loading an Existing Project
Load an existing project by selecting ‘Load From Your Device’ from the File menu.
Use the device’s interface to navigate and open your existing project. VEXcode EXP will only allow you to open files with a .expblocks, .exppython, or .expcpp file extension.
Loading an Example Project
Open an example project by selecting ‘Open Examples’ from the File menu.
Then, select an example project to open it.
Note: when opening a project, a prompt will appear asking to save if the current project has not been saved yet.
