Users can open a project in VEXcode EXP in different ways:
  • Opening an Existing Project
  • Opening a Recent Project
  • Opening an Example
Open an existing project by selecting ‘Open” from the File menu.
Then, use the macOS interface to navigate and open your existing project.
Note: VEXcode EXP C++ projects will have a .expcpp file extension, VEXcode EXP C++ projects will have a .expcpp file extension.
Open the list of recent projects from the File menu.
Then, select a recent project to open it.
Opening an Example
Open the File menu and select ‘Open Examples.’
Then, select an example project to open it.
Note: when opening a project, a prompt will appear asking to save if the current project has not been saved yet.
For more information on Example Projects, view the Using C++ Example Projects and Templates article in the Knowledge Base.
