Creating a New VEXcode EXP C++ Project
A new Blocks Project opens when you start VEXcode EXP, but you can easily create a new C++ project once VEXcode EXP is open.
Creating a New C++ Project
VEXcode EXP application icon.
Launch VEXcode EXP
New Blocks project opened in VEXcode EXP.
VEXcode EXP will open with the initial project in Blocks editor mode.
VEXcode EXP Toolbar with the File menu open and the New Text Project option highlighted. New Text Project is the second option in the menu, below New Blocks Project.
To create a C++ project, open the File menu and select ‘New Text Project.’
VEXcode EXP after the New Text Project option has been selected. A prompt reads Select a Project Language, and there are two options below for Python or C++.
Select C++ from the Project Language window.
New C++ project opened in VEXcode EXP.
VEXcode EXP will switch to C++ editor mode and load a default blank project.
