Resolving "Invalid Asset Table" Errors on a VEX V5 Brain
V5 Brain with a red error screen that reads Invalid Asset Table Version! Below there are four icons of an SD card, a refresh circle, a trash can, and a power button.
The following article will help resolve the issue of an Invalid Asset Table on your VEX V5 Brain
VEXcode V5 workspace.
Go to VEXcode V5.
V5 Brain that is powered off and has its Power Button highlighted.
Use the Power Button to turn the Brain on.
V5 Brain that is connected to a V5 Battery and a laptop.
Plug the Brain into your computer.
VEXcode V5 with a Brain Firmware prompt that reads Your VEX V5 Brain's firmware is out of date and needs to be updated. Do you want to update now? There are two buttons below, one reads No and the other reads Update.
Follow the Update prompt, if you need more information about updating your V5 brain visit this article.
