VEXos AIR Firmware Changelog
The VEX AIR Drone and VEX AIR Drone Controller each contain their own internal processors and run special software. This software is what allows for advanced programming features. The best way to ensure that your VEX AIR system is functioning properly is to keep the firmware up to date. Follow the steps in this article to update VEX AIR firmware.
The VEX AIR Drone and Controller share the same VEXos version number. Each version below applies to both devices.
VEXos Version 1.2.0
Released November 9, 2026
Competition and Field Control
  • Added a tetherless field Wi-Fi connection: the competition software sets up the field's Wi-Fi network and up to 4 pilot controllers with their team names
  • Added skills pre-pairing: the competition software saves an event's skills field on a pilot controller, and the team connects with Connect to Skills in the Competition menu
  • Added a banner with the alliance color and a Disconnect button while a pilot controller searches for a field; the search continues until the controller is unpaired
  • Changed the match types to Teamwork (two teams, 3 minutes), Auto Skills, Piloting Skills, and the new Practice Field (two teams fly against a clock the operator sets), and removed the four-team mode
  • Added a 3-2-1 countdown at Start Match, Pause Flight and Allow Flight (the match clock keeps running), and Timeouts that end on their own once every team is ready or when End Timeout Early is selected
  • Added Allow Flight and Pause Flight beside Force Land when a match ends with a drone still in the air; in Auto Skills, Allow Flight lets the pilot fly the drone down while programs are held
  • Changed landed drones to prop-lock when the match is over
  • Added the ability for the competition software to e-stop a single team and to read each team's drone module and battery level
  • Added the ability to start a match with one drone sitting out (its go button shows yellow)
  • Added the ability for the field controller to hold every drone in prop lock; drones already in the air are not affected
  • Changed drones to stop and hover when their paired field stops communicating, and to prop-lock if they are on the ground; the pilot can still land the drone
  • Limited pilot controls during Auto to takeoff, power, and e-stop, and to starting, stopping, or landing a program; the pilot's screen and settings are locked
  • Added control of the field from the competition software: the field's match buttons are hidden, the match clock follows the competition software, and the competition software can pause or resume the match and disconnect a single team
  • Changed queuing a new match to disconnect every team and remove every pilot controller from the field's Wi-Fi
  • Added a match countdown and detailed team status to the field controller's skills tile, and enlarged its top bar and dropdowns
  • Changed controllers to stay awake while paired to a field, and to not power off for inactivity while the competition software is connected
Flight
  • Improved position hold when the floor moves under the drone, when the down camera loses sight of the floor, low to the ground, over dark floors and wood grain, over platforms, and with a payload hanging in view
  • Improved height hold after hard bumps and landings
  • Improved prop lock release: releasing prop lock with the drone's button now levels the drone, so it no longer re-locks right after a crash
  • Improved how the drone turns back to its heading when spun by hand
  • Added automatic drone shutdown after 150 seconds without a controller connection
  • Changed radio signal quality to be measured instead of always showing 100%
  • Fixed an idle drone climbing when nothing asked it to
  • Fixed false descent estimates and runaway climbs
  • Fixed prop lock not engaging on a drone that is spinning on the ground, and small bumps on the ground engaging it
  • Fixed max-altitude alerts repeating when the terrain changes
Controller
  • Added WebUSB support
  • Changed drone sensor failures (camera, ToF sensor, barometer, and IMU) to show as notifications on the controller instead of as drone LED patterns
  • Added a Name, Version, Team, and Region table at the top of Settings, and a Reset Settings (factory reset) option with a confirmation
  • Added mission storage to Controller Status
  • Changed the controller's USB name to include the team number, or the robot name when no team number is set
  • Improved battery icons: the controller battery icon shows when it is charging, and battery icons turn yellow below 25%
  • Added sounds for drone photo and video captures
  • Added progress indicators for program and VEXos downloads
  • Improved the program console to show the program's own exception and keep the end of long exceptions in view
  • Fixed flight instrument readouts shifting when a sign or digit changes
  • Fixed the tap that wakes the screen also closing the open menu
  • Fixed the screen freezing while mission videos and images load
  • Fixed full storage deleting the newest mission logs instead of the oldest
Audio and Headset
  • Added support for headset volume and mute buttons
  • Added separate system volume settings for the speaker and a headset
  • Added sidetone, so you can hear your own microphone in your headset (adjustable in Settings)
  • Changed volume to adjust in steps of 5; at 50%, Mic and Headset volume pass audio through at its original level
  • Fixed the host's microphone not reaching pilots in a host practice match
VEXos Version 1.1.0
Released June 2026
  • Added competition mode
  • Added mission summary pop-ups
  • Added a warning when starting a program while the drone is prop-locked
  • Added program download date and version info
  • Added timezone and wifi_region settings
  • Improved mission delete buttons
  • Improved camera streaming
  • Improved flight, altitude, and sensor error recovery
  • Improved program start, stop, and restart behavior
  • Improved handling when the drone disconnects during a program
  • Improved error handling to reduce controller lockups
  • Improved update screens and update reliability
  • Fixed controller freezing when too many missions are saved
VEXos Version 1.01
Released December 2025
  • Added default fly program in simulator mode
  • Disabled camera buttons in simulator mode
  • Added USB mass storage for missions
  • Added idle shutdown when the drone isn't connected
  • Added error detection when a user program exits unexpectedly
  • Added the ability to set the controller name over serial
  • Improved drone and controller connection times
  • Changed the battery-full indicator to a green blip
  • Fixed serial communication issues on some Windows computers and during SDK updates
  • Fixed the drop command not updating the module state
  • Other minor bug fixes
VEXos Version 1.0
  • Initial public release
