Submitting a Virtual Skills Score in VEXcode VR
This article is for registered VEX IQ or VEX V5 teams submitting a Virtual Skills score. To submit a score, you must be logged in to VEXcode VR with your Team Number and Virtual Skills Key, not a class code. Score submissions are only open for the current season's VEX IQ and VEX V5 Robotics Competition playgrounds; older playgrounds will no longer have a Submit Score option.
Submitting your score is required to enter the VEXcode VR Autonomous Skills Global STEM Challenge.
Note: The images used in this article show the VEX IQ 26-27 Level Up Playground as an example.
Log In to VEXcode VR
Login screen showing a field to enter class code or team number, with a Submit button.
Log in using your Team Number and Virtual Skills Key. For help finding your Virtual Skills Key, see these articles for VEX V5 and VEX IQ.
VEXcode VR File menu open with Logout highlighted.
If you're already logged in to VEXcode VR with a class code, you'll need to log out first before you can log in with your Team Number and Virtual Skills Key. Select Logout within the File menu in the top-left of VEXcode VR.
Submit Your Score
Autonomous Coding Skills match in progress, with the Stop icon highlighted in the toolbar.
Manually end your match using the Stop icon, or wait for the time to run out. The Match Results window will appear.
Practice Results screen showing team number and team name fields, with Submit Score and Retry buttons.
Make sure your team number and team name are correct in the Match Results window.
Practice Results screen with the Submit Score button highlighted.
Select Submit Score to submit your Virtual Skills attempt to the leaderboard.
