Loading and Saving VEXcode V5 Projects on a Chrome Browser
A project can be loaded and saved in web-based VEXcode V5 in a variety of ways.
Create a New Project
A new project opens when VEXcode V5 is launched. But, a new project can also be opened from the File Menu.
Select ‘New Blocks Project’ from the File Menu.
Note: when creating a new project, a prompt will appear asking to save if the current project has not already been saved. See the ‘Save Using the File Menu’ section of this article for details on how to save a project.
Load an Existing Project
Open an existing project by selecting ‘Load From Your Device’ from the File menu.
Use the device’s interface to navigate and open your existing project. VEXcode V5 will only allow you to open files with a .v5blocks, .v5python, or .v5cpp file extension.
Open an Example Project
Open an example project by selecting ‘Open Examples’ from the File menu.
Rename a Project
To rename a project, select the Project Name window.
Enter the project name, and select ‘Rename.’
Open the File menu and select ‘Save To Your Device.’
Navigate to your device’s Downloads folder, you'll see a file with a .v5blocks extension (.v5python or .v5cpp if you were coding in Python or C++). This means your project has been successfully saved.
Common Issue when Loading/Saving
A common issue when using VEXcode V5 project files (.v5blocks, .v5python, or .v5cpp) is trying to select the file to be opened directly by the operating system.
If you try to open a VEXcode V5 project file (.v5blocks, .v5python, or .v5cpp) by double clicking it, it will show the following error message:
All VEXcode V5 project files (.v5blocks, .v5python, or .v5cpp) can ONLY be opened within web-based or app-based VEXcode V5. View the ‘Load an Existing Project’ section from this article for more information.
