Using the VEX V5 26-27 Override Playground Window
The VEX V5 Robotics Competition Override Playground is a virtual representation of the Field for the VEX V5 Robotics Competition Override (2026-2027) Competition game. The Playground Window is a space for the Hero Bot, Flex, to interact and move to play Override Virtual Skills.
Top-down view of Flex in the Override Playground window on the virtual competition field
How to Start, Stop, and Reset a Project
Start button in the Playground window controls used to begin the Override simulation
Select the Start button to start a project.
This button will change to a Stop button when a project is actively running.
Stop button shown in place of the Start button while a project is running in the Override Playground
Selecting the Stop button will stop the project and the timer immediately.
The Match Results Window will appear at this time. See below for more information on the Match Results Window.
Reset button highlighted in the Override Playground window controls
Select the Reset button to reset the timer, point value, and Field.
Using the Pre-Match Checklist
Pre-Match Checklist showing the starting location and Preload Orientation options for the Override Playground
The Pre-Match Checklist enables you to edit the starting location of Flex on the Field, as well as set the color orientation of the Preload in Flex's claw, with either the red or the yellow side of the Pin facing upwards.
Location button above the Start button in the Playground window controls
Select the Location icon button to open the Pre-Match Checklist.
The Pre-Match Checklist also appears upon opening the Playground window for the first time.
Pre-Match Checklist in edit mode with the four starting locations, A through D, shown on the Override field
Changing the Starting Location
The default starting location for Flex is location C. To change the starting location, select the Edit button. Then select your desired starting location, A, B, C, or D. You will see the robot change position as locations are selected.
Select Confirm to save your changes, and close the Pre-Match Checklist.
Preload Orientation toggle in the Pre-Match Checklist for the RedYellowPin in Flex's claw
Changing the Preload Orientation
By default, the Preload Orientation toggle is selected, and the Red/Yellow Pin in Flex's claw starts with the red side facing up. Unselect the toggle to start with the yellow side facing up.
Viewing Your Score and the Timer
Score display in the upper-left corner of the Playground window
Your score can be seen above the Field on the left side. This will be updated in real-time while the project is running.
Match timer in the upper-right corner of the Playground window
The timer is located above the Field on the right side.
The timer begins when a project is started and counts down from 1:00. The timer will count down until Stop is selected, the Stop project block is used in the project, or the timer reaches 0 seconds.
Using the Match Results Window
When a project is stopped, or the timer hits 0 seconds, the Match Results window will appear.
Match Results window showing the total score and team name for the Override Virtual Skills project
The total score for the project will be shown, along with the name of the team.
Match Results window with the Retry button highlighted
Select the Retry button to return to the Field and reset the timer and score.
Match Results window with the X button highlighted in the top-left corner
Select the X in the top-left corner to close the Match Results Window and return to the Field.
This will not reset the Field, timer, or score. It will return to the Field exactly as it was at the moment the project was stopped.
Expanding the Playground Window
Expand button in the top-left corner of the Playground window
The Playground window begins at a smaller size by default. If you want to expand the window, select the Expand button at the top-left corner.
Shrink button in the top-left corner of the expanded Playground window
Select the Shrink button in the top-left corner to return the window to the default size.
Hiding and Showing the Playground Window
Hide button in the Playground window toolbar
Select the Hide button to collapse the Playground Window. This will still keep the toolbar at the top of the window visible.
Collapsed Playground window with the Show button visible in the toolbar
To view the full Playground Window again, select the Show button.
Selecting Different Camera Views
Top Camera button in the Playground window controls
Select the Top Camera button to see an overhead view of the entire Field. This is the default view when you open the Override Playground Window.
Chase Camera button in the Playground window controls
Select the Chase Camera button to see a behind-the-robot view.
Orbit Camera button in the Playground window controls
Select the Orbit Camera button to see a perspective view of the robot on the Field.
Driver Station Camera button in the Playground window controls
Select the Driver Station Camera button to see a perspective view, as if you were standing at the Driver Station by the Field.
Using the Match Load Buttons
Six Match Load buttons on the right side of the Playground window, showing the two Pin types and the Cup, each with two orientation options
The Match Load buttons are located on the right side of the Playground Window. While a project is running, select one of the six buttons to place that Game Element in the Loader. You can place a Blue/Yellow Pin, a Red/Yellow Pin, or a Cup, and choose which side of the element will face up.
A Red Yellow Pin placed in the Loader closest to Flex on the Override field
Game Elements are always placed in the Loader closest to Flex. Selecting additional buttons will not place a Game Element in the farther Loader.
A Pin and a Cup stacked together in the Loader on the Override field
You can place a Pin by itself, a Cup by itself, or a Pin and a Cup together in either order — a Pin with a Cup on top, or a Cup with a Pin on top. Two Pins or two Cups cannot be placed together.
Once the Loader is holding a Pin and a Cup, no additional Game Elements can be placed until the contents of the Loader have been moved out.
Viewing AI Vision
AI Vision button in the lower-right Playground controls, above the camera buttons
Select the AI Vision button to view the AI Vision camera viewer.
AI Vision viewer showing X, Y, width, and height values for detected pin and cup game elements in the Playground window
Data from the AI Vision will appear in a window to the left side of the Field. Here you will see the camera view from the AI Vision sensor, with data about any game elements or AprilTag IDs in view.
To learn more about using AI Vision in the Override Playground, view the Blocks and Python support in the VEX API (Coming Soon).
Viewing Additional Information
Info button below the timer in the Playground window
Select the Info icon to open the User and Hardware Information window.
Graphics and Performance Summary window showing system performance details for the Override Playground
Data about your device will be displayed in the User and Hardware Information window. This can be used to help troubleshoot any performance issues.
Select the X button in the upper-left corner to close the window and return to the Playground.
