After completing an Introductory Certification, Competition Certification, Masterclass, 1-on-1 Session, or attending the VEX Robotics Educator Conference, you may want to download or share your certificate.
This article covers how to access your certificates.
Start by going to pd.vex.com and select Login.
Login using your VEX Account.
On the right side of your PD+ Dashboard, you will see a Certifications section beneath your profile information.
Select View All Certificates to open a list of all certificates you have earned.
Each certification you have earned will show the certificate name, platform, and the date earned. The right-most column shows options for downloading the certificate as well as icons to share the certificate through different social media sites.
After you have downloaded or shared your desired certificate(s), you can close the window using the X in the upper right corner.
