Naming Your Brain with VEX IQ (2nd gen)
The VEX IQ (2nd gen) Brain can be renamed, making it easier to identify which Brain is which.
VEXcode IQ with the Brain icon on the Toolbar highlighted. The Brain icon is highlighted green to indicate that it is connected.
When the Brain is connected, open the Brain dropdown.
VEXcode IQ with a connected Brain and the Brain dropdown menu opened. In the menu, the edit button next to the Brain's name is highlighted.
Select the edit button next to the Brain's current name.
VEXcode IQ Brain Name menu opened where the name can be changed. The Update button below is highlighted.
Update the name, then click update.
Note: Spaces are not accepted. To separate words, use underscores.
VEXcode IQ with a connected Brain and the Brain dropdown menu opened. In the menu, the Brain's name has been updated.
You will now see the updated Brain name.
