Get Started with an EXP Classroom Bundle
When you get your VEX EXP Classroom Bundle, there are a few things you can do to get yourself organized and started. This article will cover the basics of unpacking your Classroom Bundle and getting ready to use VEX EXP with your students.
Product image for the VEX EXP Classroom Bundle with its contents shown stored in the kits and the case. In front of the storage kits, a Field is set up with an EXP Clawbot and game pieces placed on it.
Note: All of the resources in this article are based on a Small Classroom Bundle. If you ordered a Classroom Bundle, you will receive the equivalent of two Small Classroom Bundles. If you ordered a Large Classroom Bundle, you will receive the equivalent of three Small Classroom Bundles.
This article reviews all of the pieces in your VEX EXP Small Classroom Bundle and where you can find them.
  • Part: This is the name of the part.
  • Photo: This is an image of the part. Use this for reference while unboxing your Classroom Bundle.
  • Quantity: This is the quantity of each part provided.
  • Location: This is where you can find the parts in your Classroom Bundle.
  • Helpful Hints: These are provided in the Location column. These hints provide extra context or information on packaging, identifying part numbers, or tips for additional organization.
Part Photo Quantity Location
EXP Education Kits - Structure Bin VEX EXP Education Kit - Structure Bin. 5
Helpful Hint:
Label each bin so that the Structure bin and the Electronics bin remain paired together as you distribute kits in the classroom.
Note that the structural metal will come in a separate box and will need to be placed inside the red Structure bin when unpacking.
EXP Education Kits - Electronics Bin VEX EXP Education Kit - Electronics Bin. 5
Helpful Hint:
Note that the electronics will come in a separate box and will need to be placed inside the red Electronics bin when unpacking.
Field Tiles VEX EXP Field Tile piece. 16
These will be located in the red Carrying Case.
Field Walls VEX EXP Field Wall piece. 16
Buckyballs 2 VEX EXP Buckyball pieces are shown, one red ball and one blue ball. 12
Helpful Hint:
You will receive 6 Buckyballs of each color: red and blue.
Rings 3 VEX EXP Ring pieces are shown, one blue ring, one red ring, and one green ring. 6
Helpful Hint:
You will receive 2 Rings of each color: red, green, and blue.
Extra Tools EXP T15 Star Screwdriver piece. 5
These will be located in the red Carrying Case. Remember to check the zipper pockets while unpacking the case.
Helpful Hint:
With two students per kit and the extra tools, there are enough for each student to have a tool to use while building.
Extra USB Cables 5 USB Cables for use with VEX EXP. 5
Helpful Hint:
Keep the extra USB cables with the Classroom Chargers so the USB cables in the Electronics Bin can be used for connecting to VEXcode EXP.
Classroom Chargers 2 Classroom Chargers are shown, the larger one has 4 USB ports and the smaller one only has 1 USB port. 2
Helpful Hint:
There are 5 USB ports between the two chargers, so you can charge 5 EXP Brains or 5 EXP Controllers with one outlet. Keep the extra USB cables with the Classroom Charger so the USB cables in the Electronics Bin can be used for connecting to VEXcode EXP.
Extra Screws
  • 0.375"
  • 1.0"
  • 1.5"
  • 0.25" Locking
Jewel Case with several types of extra Screw pieces. 1 Jewel Case with 160 screws
All extra jewel cases will be located in the red Carrying Case underneath the Buckyballs and Rings.
Helpful Hint:
Each set of extra parts will be contained in a small jewel case. Remove these and keep them in a teacher-only area to ensure your extra parts are not mixed into existing EXP Kits.
Extra Nuts and Washers Jewel Case with extra Nut and Washer pieces. 1 Jewel Case with 200 Nuts and 100 Washers
Helpful Hint:
Extra High Strength Shaft Adapters
  • Square Bore
  • Round Bore
Jewel Case with extra High Strength Shaft Adapter pieces. 1 Jewel Case with 30 High Strength Shaft Adaptors
Helpful Hint:
Extra Rubber Shaft Collars Jewel Case with extra Rubber Shaft Collar pieces. 1 Jewel Case with 50 Rubber Shaft Collars
Helpful Hint:
Extra Hex Nut Retainers
  • 4 Post
  • 1 Post
Jewel Case with extra Hex Nut Retainer pieces. 1 Jewel Case with 30 Hex Nut Retainers
Helpful Hint:
Extra Bearings
  • 1 Post Standoff Retainer with Bearing Flat
  • Shaft Collar Retainer with Bearing Flat
  • Low Profile Bearing Flat
Jewel Case with extra Bearing pieces. 1 Jewel Case with 35 Bearings
Helpful Hint:
Carrying Case for Field Tiles, Walls, and Game Elements VEX EXP Carrying Case for Field Tiles, Walls, and Game Elements. 1
This Carrying Case will contain all of the extra parts, the parts poster, and game elements of your EXP Classroom Bundle.
