Connecting to the Brain with Web-Based VEXcode EXP - Chromebook
It takes just a few steps to connect a VEX EXP Brain to Web-based VEXcode EXP on Chromebook.
How To Connect a VEX EXP Brain from Web-based VEXcode EXP on a Chromebook
EXP Brain with its Check button highlighted.
Be sure the EXP Battery is charged and is connected to the EXP Brain.
Turn on the Brain by pressing the Check button on the Brain.
Brain connected to a laptop computer using a USB cable.
Connect the EXP Brain to your Chromebook, using the USB-C cable.
Note: Your EXP Brain must remain plugged into your Chromebook throughout the connection process.
VEXcode EXP Toolbar with the Brain icon highlighted in between the Controller and Download icons.
Launch web-based VEXcode EXP by navigating to codeexp.vex.com.
Select the Brain icon in the Toolbar.
VEXcode EXP with the Brain dropdown menu opened and the Connect button highlighted.
Select ‘Connect'.
VEXcode EXP Browser Connection prompt that reads Your browser will now prompt you to connect to your EXP Brain. Please select the EXP Brain with the lowest ID number and press Connect on the connection prompt. There are two buttons below, one reads Cancel and the other reads Continue. The Continue button is highlighted.
A text box will appear and explain that you should choose the Brain that has lowest ID number. Select 'Continue' on the text box to open the connection window.
Browser connection window, with two items titled VEX Robotics EXP Brain. One item has an ID number of ACM6 and the other is ACM7, the item with the ID number of ACM6 is highlighted.
Select the EXP Brain with the lowest ID number from the list of Brains available.
Browser connection window, with the item with the ID number of ACM6 selected and highlighted. Below, the Connect button is highlighted.
Select the ‘Connect’ button, once you have chosen the lowest numbered EXP Brain ID.
VEXcode EXP Toolbar with the green Brain icon highlighted, indicating that the Brain is connected.
Once the EXP Brain is successfully connected the Brain icon will turn green.
VEXcode EXP Browser Connection prompt that reads Your browser connected to the incorrect EXP port, please select the not currently paired EXP Brain and press Connect on the connection prompt to try again. There are two buttons below, one reads Cancel and the other reads Continue.
If the connection was unsuccessful, another text box will appear and prompt you to select the Brain with the different ID number.
To Disconnect a VEX EXP Brain from Web-based VEXcode EXP on Chromebook
Brain that was connected to a laptop computer using a USB cable. Now, the USB cable has been unplugged from the Brain.
To disconnect your device from an EXP Brain, unplug the USB-C cable from your Chromebook or the EXP Brain.
