Using the Printable VEX EXP Parts Ruler
Whether organizing parts, following a set of build instructions, or building a custom design, identifying a part correctly can be crucial to your success.
The VEX EXP Parts Ruler is a handy tool to help identify parts.
Note: when printing the .pdf be sure to set to 100% scale.
Using the Ruler to Identify Parts
The VEX EXP Parts Ruler can be used to identify parts while organizing parts or following a set of build instructions. The scale on the ruler is 1:1, so parts can simply be placed on top of the ruler.
Printable VEX EXP parts rulers with marking showing how the rulers are to scale
Measuring Structural Metal. Example shown is a 4x4 Plate.
  • 4 indicates a width of 4 pitch units.
  • 4 indicates a length of 4 pitch units.
Close up of a screw from the EXP ruler with different screw measurements shown
Measuring Screws. Example shown is a #8-32 1.0 inch Star Screw.
Close up of the spacers on the ruler, with a .125' spacer being compared to the same size spacer on the ruler.
Measuring Spacers. Example shown is a 0.125 inch Spacer.
Close up of the gears on the ruler, with the 12 Tooth Gear highlighted
Measuring Gears. Example shown is a 12 Tooth Gear.
A VEX EXP sprocket being compared to the sprockets on the rules, with the 16 tooth mark called out
Measuring Sprockets. Example shown is a 16 Tooth Sprocket.
A standoff being compared to the standoff markings on the ruler
Measuring Standoffs. Example shown is a 0.5 inch Standoff.
Printable VEX EXP parts ruler with inch and millimeter measurements for identifying part sizes
Measure Shafts. Example shown is a 2 inch Shaft.
Using the Ruler While Assembling a Robot
The VEX EXP Parts ruler can also be used as a measuring tool to measure parts and distances. This can be very helpful when designing and assembling a custom robot which does not have specific instructions regarding the selection of parts.
Tip and trick: The .pdf of the VEX EXP Parts Ruler can be printed out on a clear plastic transparency. This will allow the ruler to be overlaid on the robot and measurements can be made by measuring through the ruler.
Here are some examples of using the ruler while assembling a custom robot.
Printable VEX EXP parts rulers with measurement markings for identifying shaft engths
Measuring the distance between C-Channels on a robot chassis. This example shows the C-Channels on the robot chassis measuring 14 pitch or 7 inches.
Printable VEX EXP parts ruler with labeled measurement scales for identifying wheel sizes
Using inches/millimeters to measure the diameter of wheels. Example shown is a 3.25 inch Travel Wheel (3.25 inches/260 millimeters).
Printable VEX EXP parts ruler with measurement markings for identifying chain sizes
Measuring the number of chain links in a chain/sprocket system.
