Saving an EXP Python Project on macOS
When working in VEXcode EXP, it is important to understand how to save a project on a macOS device.
Ways to Save
You can save your project in VEXcode EXP in different ways:
VEXcode EXP Toolbar with the File menu open and the Save option highlighted. Save is the fifth option in the menu, below New Blocks Project, New Text Project, Open, and Open Examples.
Option 1: Selecting Save in the File menu.
VEXcode EXP Toolbar with the Download icon highlighted in between the Brain and Run icons.
Option 2: Downloading a new project.
VEXcode EXP Toolbar with the project name field highlighted. To the right of the project name a label reads Not Saved.
Option 3: Naming a new project by selecting the project name window.
VEXcode EXP Project Name dropdown menu opened where the name can be changed. The Save button below is highlighted.
Then select the Save button.
Saving a Project
The device's Save As menu is open and set to save to the Documents folder.
Choose one of the ways above to save a new project, then a Save As dialog window will open.
The device's Save As menu is open and set to save to the Documents folder. The Save As field that can be used to name the project is highlighted.
Name your project by typing in your device's save dialog window.
The device's Save As menu is open and set to save to the Documents folder. The Where field that can be used to set the file's destination is highlighted.
Select the destination, such as the Documents folder.
The device's Save As menu is open and set to save to the Downloads folder. The Save button in the bottom right is highlighted.
Then select Save.
VEXcode EXP Toolbar with the project name field highlighted and changed to Drive Project.
The updated project name will be visible in the project name window.
VEXcode EXP Toolbar with the project name field changed to Drive Project. The label to the right is highlighted and reads Saved.
Once a project is saved, VEXcode EXP will automatically save all changes in a project.
VEXcode EXP unsaved project prompt that reads Your project was never saved. Save now? Below there are two buttons, one reads Discard and the other reads Save.
Note: Whenever there is an unsaved project, VEXcode EXP will prompt users to save their work if the user attempts to:
  • Close VEXcode EXP
  • Create a new project
  • Open another project
Using 'Save As'
VEXcode EXP Toolbar with the File menu open and the Save As option highlighted. Save As is the sixth option in the menu, below New Blocks Project, New Text Project, Open, Open Examples, and Save.
You can also use the Save As option from the File menu to make a copy of a project under a different name or in a different location.
