Understanding the Colorization of Code in VEXcode VR Python
When creating Text projects, the syntax, spacing, indenting, and spelling in your code in very important to ensure that your project runs as intended. The color coding present in the Workspace in VEXcode VR Python is an extra visual cue that you have entered your code into your project correctly.
If there is an unrecognizable component while typing commands into the Workspace, it will remain black (like the user-created category). This can be a useful indicator as you are working to prevent frustration or extra troubleshooting later on.
Use the cursor and keyboard to correct errors. As the components are recognized, they will be colorized correctly.
The colorization of code follows the following conventions:
Classes
VEXcode VR Python editor showing syntax colors for commands, variables, and comments
The individual device the command pertains to (i.e. drivetrain, pen, brain)
Commands
Project Help panel listing Python command categories with example syntax in VEXcode VR
The behavior within the command (i.e. drive, turn)
Parameters
Project Help example showing the [ ] placeholder for a required Python command parameter
Information about how the behavior executes (i.e. direction, distance)
Structures
VEXcode VR Python project with syntax highlighting for commands, numbers, and comments
Control the flow of the project (i.e. conditionals, loops)
Values
VEXcode VR Python syntax highlighting shows different colors for commands, numbers, and comments
Numerical parameter assigned to the behavior (i.e. number of degrees of a turn)
User Created
VEXcode VR Python editor showing syntax colors for commands, numbers, and comments alongside Help examples
User created variables and commands
Comments
Project Help panel showing Python syntax color examples in VEXcode VR
The text following a # that will not effect the program.
