Naming Your EXP Brain
The VEX EXP Brain can be renamed, making it easier to identify which Brain is which.
VEXcode EXP with the Brain icon on the Toolbar highlighted. The Brain icon is colored green to indicate that it is connected.
When the Brain is connected, open the Brain dropdown.
VEXcode EXP with a connected Brain and the Brain dropdown menu opened. In the menu, the edit button next to the Brain's name is highlighted.
Select the edit button next to the Brain's current name.
VEXcode EXP Brain Name menu opened where the name can be changed. In this example, a name has been entered that reads New_EXP_Brain. The Update button below is highlighted.
Update the name, then click update.
Note: Spaces are not accepted. To separate words, use underscores.
VEXcode EXP with a connected Brain and the Brain dropdown menu opened. In the menu, the Brain's name has been updated to New_EXP_Brain.
You will now see the updated Brain name.
