While V5 STEM Labs were designed for the VEX V5 Kit and follow the SPARK format, there are many ways to teach these STEM Labs with your EXP Kit. In this article, we provide you with resources to help adapt V5 STEM Labs, giving you the flexibility to teach both V5 and EXP STEM Lab Units.
To see how to incorporate both EXP and V5 STEM Labs together in your classroom, see the EXP Cumulative Pacing Guide.
Overall Considerations When Teaching V5 STEM Labs with EXP Kits
V5 STEM Labs follow the SPARK format. To learn more about each section and what is covered, see this article. When adapting these Labs to use with EXP, there are some overarching adaptations that can be made.
- Seek: Follow the build instructions for EXP linked below.
- Play: Adaptations for the play activities will be outlined in the "Adaptations" section.
- Apply: This section can remain the same.
- Rethink: Adaptations for the rethink challenges will be outlined in the "Adaptations" section.
- Know: This section can remain the same.
The Play section in coding STEM Labs covers the set up and other information about VEXcode V5. For information about downloading and using VEXcode EXP, see this section of articles.
The following section identifies an V5 STEM Lab, the V5 build that is used for that Unit, and a compatible EXP Build that you can use to complete the practice and challenge activities. Also included are suggestions for adapting the Play and Rethink activities for each Lab.
Robo Rally
Students are asked to use proportional reasoning and scale to design a race course for the Speedbot. See the teacher version of the Robo Rally STEM Lab here.
| V5 Build | Recommended EXP Build | Adaptations |
Speedbot |
BaseBot |
Robosoccer
Students are asked to build and utilize a robot to dribble a ball and iterate on its design. See the teacher version of the Robosoccer STEM Lab here.
Speedbot |
BaseBot |
Medbot
Students are asked to program a robot to deliver medication to patients on a hospital floor that they create. See the teacher version of the Medbot STEM Lab here.
Speedbot |
BaseBot |
Momentum Alley
Students code a robot to knock down bowling pins using what they know about forces. See the teacher version of the Momentum Alley STEM Lab here.
Speedbot |
BaseBot |
It's a Draw
Students will explore the Clawbot and using it as an artistic tool in a drawing game. See the teacher version of the It's a Draw STEM Lab here.
Clawbot |
Clawbot |
Speedy Delivery
Students are asked to program a robot to navigate a warehouse and to prepare packages for delivery. See the teacher version of the Speedy Delivery STEM Lab here.
Clawbot |
Clawbot |
Design By Request
Students will go through the engineering design process for an open-ended build activity. See the teacher version of the Design By Request STEM Lab here.
| N/A. This is a custom build as part of the STEM Lab. |
Loop, There It Is!
Students will learn how to program loops to get their robot grooving. See the teacher version of the Loop, There It Is! STEM Lab here.
Clawbot |
Clawbot |
Gravity Rush
Students will explore the Clawbot and issues of center of gravity as they prepare for a race. See the teacher version of the Gravity Rush STEM Lab here.
Clawbot |
Clawbot |
To Do, or Not To Do
Students are asked to program their robot to act on conditionals. See the teacher version of the Loop, There It Is! STEM Lab here.
Clawbot |
Clawbot |
Clawbot with Controller
Students will code the Controller to direct the Clawbot through several engaging challenges using the concept of loops. See the teacher version of the Clawbot with Controller STEM Lab here.
Clawbot |
Clawbot |
Vision Sensor
Students will use the Vision Sensor to detect objects. See the teacher version of the Vision Sensor STEM Lab here.
Clawbot |
Clawbot |
Mechanical Advantage
Students will explore how mechanical advantages and gear ratios can be applied in their builds, daily lives, and in robotics competitions. See the teacher version of the Mechanical Advantage STEM Lab here.
Note: Because the EXP version does not have specific build instructions, this is a harder lab to complete. Students will need to determine the best way to adapt the instructions while building in order to make the EXP version. This is recommended for students who are advanced in engineering.
V5 Gear Box |
Custom EXP Gear Box Note: This is just one example of how to construct a gear box with the EXP Kit. |
