Downloading a Blocks Project to a Selected Slot in VEXcode EXP
The VEX EXP Brain has eight slots to store downloaded programs. You can choose which slot to use by setting the slot within VEXcode EXP.
VEXcode EXP Toolbar with the Slot icon highlighted in between the Redo button and the Project Name field.
The Slot icon is located next to the Project Name.
VEXcode EXP with the Slots dropdown menu opened. The menu has 8 available slots for downloading projects to the Brain.
Select the Slot icon to change which slot to download the project to on the VEX EXP Brain.
VEXcode EXP Toolbar with the Download icon highlighted in between the Brain and Run icons.
Select the Download button to download the project to the select slot. Keep in mind that downloading will replace the previous program using the selected slot.
EXP Brain screen is shown with the Programs menu opened and a program named squareDance selected.
Run your program by selecting it from the main menu the VEX EXP Brain. The Project Name will also appear in the main menu to help recall which program slot is being used.
