Running User Programs from EXP Brain
VEX EXP Brain
User Programs downloaded to the Brain can be found in one of 8 slots for User Programs, numbered 1 - 8 in the Programs menu.
Brain screen is shown in the Home menu with the Programs option selected. Programs is the second option in the Home menu.
Use the left and right buttons to highlight the Programs menu option, then press the Check button to select Programs.
Brain screen is shown in the Programs menu with a VEXcode Project in slot 1 selected and named algorithm.
In the Programs menu, you will see the User Programs downloaded to the Brain. In this example image, there are three User Programs downloaded in slot 1 and slots 2 and 3.
  • Use the left and right buttons to scroll to your desired program.
  • Press the Check button to select the program.
Brain screen is shown in the Project menu for the project named algorithm. The Run option is selected.
Once your program is selected, you can run your project by pressing the check button.
