Using Comment Blocks in VEXcode EXP
Comments are usually added to projects to explain what a programmer wanted parts of the program to do. So they are helpful when collaborating and troubleshooting.
VEXcode EXP blocks workspace that shows a Comment block being dragged into a stack of blocks.
Drag a “comment” block and attach it to any block in a stack.
VEXcode EXP blocks project with a Comment block that has a highlighted text field and reads Type your comment here.
Type any text, numbers, or symbols into the “comment” block.
VEXcode EXP blocks project with a Comment block that has a saved message in its text field that reads Type your comment here.
When you finish the comment, click anywhere outside of the comment or press the “Enter” or “Return” key to finish editing the comment.
Note: The inside of the comment block will turn from white to gray when finished.
