Installing or Removing EXP Brain Battery
Before installing, you should have a charged VEX EXP Battery.
Install the Battery
Diagram shows a Battery being connected to an EXP Brain. An arrow indicates that the Battery should be slid into the charging port on the bottom of the Brain. The Battery is oriented with its latch facing away from the Brain.EXP Brain with a connected Battery.
Slide the Battery into the VEX EXP Brain and listen for a click that indicates the Battery has been inserted correctly and completely.
Remove the Battery
Diagram shows the two steps to remove the Battery from the EXP Brain. The first step has an arrow pointing at the Battery's latch to indicate that it must be pressed down. The second step shows the Battery sliding out from the Brain.
Squeeze the latch at the end of the Battery and pull it out of the Brain.
NOTE: Pushing on the Battery from the other end helps in removing it.
NOTE: The Battery should always be removed from the Brain if it is going to be stored for longer than two weeks.
