It takes just a few steps to connect a VEX EXP Brain to App-Based VEXcode EXP on your Windows or Mac computer. First, you will need to be sure you have all the components.
You will need the following:
- A USB-C cable (either USB-C to USB-C, or USB-C to USB-A, depending on your device)
- An EXP Brain
- An EXP Battery
- A Windows or Mac Computer
After you have gathered your components, complete the following:
Insert the battery into the EXP Brain.
Turn on the EXP Brain by pressing the checkmark button.
Connect the USB-C cable to the EXP Brain.
Connect the other end of the USB cable to the Computer’s USB port.
Launch app-based VEXcode EXP
A successful connection is confirmed when the Brain Status Icon in the Toolbar is green.
