Deleting a Block in VEXcode EXP
Blocks in VEXcode EXP can be deleted in a number of ways.
Drag to Delete
VEXcode EXP Workspace with a block being dragged back into the Toolbox to delete it.
Select a block or a stack of blocks in the Workspace and drag them left to the Toolbox to delete from your project.
Delete a Single Block from a Stack
VEXcode EXP Workspace with a block's context menu opened and the Delete Block option highlighted.
To remove a single block from a stack, context-select (right click or long press) a block in a stack and then choose 'Delete Block' from the context menu. This will also delete any nested blocks if a block with parameters is chosen to be deleted.
Delete All Blocks
VEXcode EXP Workspace with the background's context menu opened and the Delete X blocks option highlighted. This option will delete all blocks in the workspace except for the When Started block.
To remove all of the blocks in the Workspace, context-select (right click or long press) the background of the Workspace and choose 'Delete X Blocks.'
