Features of the VR Rover
The VR Rover in VEXcode VR is equipped with sensing capabilities and a variety of controls.
VEXcode VR Rover Rescue challenge interface with the Rover playground and block-based coding workspace
VR Rover Controls
The VR Rover has the following controls:
  • A drivetrain with a built-in gyro. This enables the “Drivetrain” category of commands in the Toolbox of VEXcode VR to drive and turn the robot. The gyro allows the robot to make accurate and precise turns. The drivetrain heading reports a value from 0 to 359.9 degrees, and clockwise is positive.
VEXcode VR Rover Rescue challenge interface with the rover playground and block-based coding workspace
  • The VR Rover can pick up a mineral sample and use it or carry it around the alien environment.
  • Because enemies can be found throughout Rover Rescue, the VR Rover has the ability to neutralize irradiated enemies by absorbing their radiation. Neutralizing may be beneficial in these scenarios:
    • To gather the minerals that enemies are protecting
    • To collect energy from neutralizing enemies
    • To defend against an enemy that has sensed the VR Rover
For more information on neutralizing enemies, see this article.
VR Rover Physical Attributes
The VR Rover has the following physical attributes:
  • The VR Rover is approximately 191 millimeters (mm) long and 147 millimeters (mm) wide
  • A multi-purpose claw used to collect minerals
VR Rover Sensing
The VR Rover has the following sensing capabilities:
  • A Distance Sensor that returns the distance of a detected object in millimeters (mm) and inches
  • A Location Sensor that reports the VR Rover's position. This is done with (X,Y) coordinates in millimeters (mm)
  • Built-in AI technology for detecting minerals and enemies, and seeing minerals, obstacles, the Base, and enemies
  • Additional sensing capabilities include:
    • Ability to detect when the VR Rover is under attack
    • Ability to report the amount of minerals stored at the Base
To learn more about the VR Rover’s AI, see this article.
