Converting an IQ (1st gen) project to use with an IQ (2nd gen) Brain
While working with VEX IQ, you may want to run a project that was configured for a (1st generation) Brain on a robot with a (2nd generation) Brain. In this scenario, you will need to convert your project from '1st gen' to '2nd gen' in VEXcode IQ.
VEXcode IQ Devices menu with the IQ Robot Brain generation setting shown. This setting is set to the 2nd gen option.
In most cases, there will not be any changes to the project during the conversion. However, there are a few instances where minor changes are made automatically when certain blocks are used in a 1st generation project. These changes will not affect how your project runs on an IQ (2nd generation) Brain.
Converting a Project with No Gyro - No Changes to Code
VEXcode IQ with a 1st generation project in the workspace. The Devices icon is highlighted in between the Code Viewer and the Help icons.
Open a (1st generation) project in the workspace. Then, select the Devices window icon.
VEXcode IQ Devices menu with the IQ Robot Brain generation setting shown. This setting is set to the 1st gen option, but the 2nd gen option is highlighted.
Once the Devices window is open, select the '2nd gen' icon.
VEXcode IQ Devices menu with the IQ Robot Brain generation setting shown. This setting has been switched to 2nd gen and it is highlighted.
If no Gyro was configured, the '2nd gen' icon will highlight in blue to show that the project has been converted. You can now run this project on a (2nd gen) Brain.
Converting a Project with Gyro Configured - No Changes to Code
If you have a Drivetrain with a Gyro configured, you will need to either configure the Gyro with the IQ (2nd gen) Brain, or configure the Brain Inertial Sensor that is emedded in the IQ (2nd gen) Brain.
VEXcode IQ Brain Generation prompt that reads 1st generation IQ Robot Brain projects need to be converted before being used with a 2nd generation IQ Robot Brain. Do you wish to proceed with conversion? There is a link to Lean More below. There are also two buttons below, one reads Cancel and the other reads Continue. The Continue button is highlighted.
If you have a Drivetrain with a Gyro configured, you will need to manually configure the external Gyro, or configure the Brain Inertial Sensor.
In this scenario, a conversion dialog window will open. Select 'Continue' to proceed with the conversion.
Note: If you do not have a Gyro configured, you will not get this message and your project will be converted.
VEXcode IQ Select Gyro Type prompt that has a message that reads This project uses a Drivetrain with a Gyro. Please select the type of Gyro data to use with your VEX IQ (2nd gen) robot. Below there are two options, one reads External Gyro and the other reads Brain Inertial.
You will be prompted to select the Gyro configuration; either Externail Gyro or Brain Inertial. Select one.
  • If External Gyro is selected, it will be configured for the same port as was previously configured.
  • If Brain Inertial is selected, your project will use the Brain Inertial Sensor embedded in the Brain, and the port will be free to use with other devices.
VEXcode IQ Project Conversion prompt that reads Project conversion has been completed with these changes. The Drivetrain's Gyro Sensor was replaced with the Inertial. There is an OK button below.
A message will appear to alert you that the project has been converted. Select 'OK' to proceed.
VEXcode IQ Devices menu with the IQ Robot Brain generation setting shown. This setting has been switched to 2nd gen and it is highlighted. The Drivetrain device is also shown, and its Inertial icon is highlighted to indicate that the project is now using the Brain's built in Inertial Sensor.
The '2nd gen' icon will highlight in blue to show that the project has been converted. You can also see that the Brain Inertial Sensor has been configured.
Note:  If this project is converted back to 1st gen, the external Gyro will not automatically be configured. It will need to be manually configured in the Devices window.
Note: The conversion process will also start when a IQ (2nd gen) Brain is connected while VEXcode is in 1st gen mode.
Converting a Project with Minor Changes to Code Made Automatically
A message will appear to alert you that the project will need to be converted. Select 'Continue' to proceed with the conversion.
Note: This message will only open if changes were made to the project code.
VEXcode IQ Project Conversion prompt that reads Project conversion has been completed with these changes. {When Brain button} event block dropdown menu updated. There is an OK button below that is highlighted.
A conversion completion message will open and list any changes that were made. In this example, the {When Brain button} event block dropdown menu was updated from 1st to 2nd generation configuration.
  • See the section below for more information on the different messages that you may receive, and how to interpret them.
Select 'OK' to save the project conversion.
The '2nd gen' icon will be highlighted in blue to show that the project has been converted. You can now run this project on a (2nd generation) Brain.
Interpreting Dialog Messages when Converting Projects
If there was a conversion to the code needed due to any of the conditions shown below, the message after conversion will be: "Project conversion has been completed with these changes," followed by a list of any changes that were made to the code. Below are the changes that you may encounter when converting a (1st generation) project to run on a (2nd generation) Brain.
{When Brain button} Dropdown Menu Updated
VEXcode IQ Project Conversion prompt that reads Project conversion has been completed with these changes. {When Brain button} event block dropdown menu updated. There is an OK button below.
Here the message tells you that the conversion is completed, and the dropdown menu of the {When Brain button} block has been updated.
Diagram of the When Brain Button block that has a different dropdown menu of buttons depending on the Brain generation. The 1st gen menu has three options that read Up, Down, and Check. The 2nd gen menu has three options that read Left, Right, and Check.
Because the Arrow buttons on the (1st gen) Brain are 'Up' and 'Down', but they are 'Left' and 'Right' on the (2nd gen) Brain, the parameters in the dropdown menu for the Blocks connected to the Arrow buttons have to be updated.
VEXcode IQ Project Conversion prompt that reads Project conversion has been completed with these changes. Brain Button Pressed sensing block dropdown menu updated. There is an OK button below.
Here the message tells you that the conversion is completed, and the dropdown menu of the <Brain button pressed> block has been updated.
Diagram of the Brain Button Pressed block that has a different dropdown menu of buttons depending on the Brain generation. The 1st gen menu has three options that read Up, Down, and Check. The 2nd gen menu has three options that read Left, Right, and Check.
Drivetrain Gyro Update
Here the message tells you that the Drivetrain Gyro Sensor was replaced with the Inertial sensor.
VEXcode IQ Devices menu is open and the Robot Brain generation setting is set to 2nd gen. The Drivetrain device is shown and its Inertial icon is highlighted to indicate that the project is now using the Brain's built in Inertial Sensor.
You will see the Inertial Sensor Icon in the Devices.
Note:  If this project is converted back to 1st gen, the external Gyro will not automatically be configured. It will need to be manually configured.
