Understanding Indicator Lights - IQ Controller (2nd gen)
Using VEX IQ (1st generation)? See this article.
Notice there are two different indicator lights on the VEX IQ (2nd generation) Controller.
Power LED
The first indicator light is called the Power LED.
IQ (2nd gen) Controller with its Power LED highlighted.
There are three possible colors of the Power LED to indicate the status of the VEX IQ Controller Battery and of the VEX IQ Radio Link:
Power LED Color   Controller Status Controller Battery Status
Icon of a solid green indicator light.
Solid Green Controller ON - NOT paired with a Brain Controller Battery level sufficient
Icon of a blinking green indicator light.
Blinking Green Controller ON - Paired with a Brain Controller Battery level sufficient
Icon of a solid yellow indicator light.
Solid Yellow Actively Pairing
Icon of a solid red indicator light.
Solid Red Controller ON Controller Battery level low
Icon of a blinking red indicator light.
Blinking Red Controller ON - Paired with a Brain Controller Battery level low
Fast Red Blinking Firmware on your controller is failing to load. View this article. N/A
If the Controller is not wirelessly connected to a VEX IQ Brain, see this article for more information about wirelessly pairing a VEX IQ (2nd generation) Controller and Brain.
Charge LED
The second is called the Charge LED. This LED will only illuminate when the Controller is plugged into a charger.
IQ (2nd gen) Controller with its Charge LED highlighted.
There are three possible colors for the Charge LED: green, red, and gray.
Charge LED Color   Status
Solid Green Controller Battery is completely charged
Solid Red Controller Battery charge in progress
Blinking Red Controller Battery fault
Icon of an indicator light that is turned off.
Off Not charging
See this article for information on how to charge a VEX IQ (2nd generation) Controller.
