Using VEX IQ (1st generation)? See this article.
The Buttons on the Brain
On the Brain there are four main buttons that are used to navigate the Brain screen:
The Check button
The Check button is used to power on the Brain as well as to select different choices on the screen.
The X button
The X button is used to power off the Brain. It is also used as a “go back” button to return to previous screens.
The Left and Right Buttons
The left and right buttons are used to navigate between different options on the Brain screen.
The Home Screen
When the Brain is turned on with the Check button, the Home Screen will appear, and the green indicator light with show green.
To the left is an example of the Brain screen when it is powered on, with each element labeled for reference.
