Legacy - Preventing Air Leakage in a VEX Pneumatic System
An important concern when working with a VEX pneumatic system is air leakage. Any air leaks in the system will reduce the overall pressure and the amount of cycles (extend/retract) the pneumatic system will be able to operate.
Preventing Leaks in Reservoir Fittings
Reservoir Fitting piece.
Schrader Tire Fitting piece.
The Air Reservoir fittings consist of the Schrader tire pump valve and the Reservoir fitting
The Reservoir fitting’s threads come with teflon already applied to create a leak-free seal.
Tire pump fitting piece with a layer of Teflon tape wrapped around its threads for an airtight seal.
Roll of Teflon tape.
A single layer of Teflon tape can be wrapped around the threads of the Schrader tire fitting prior to screwing it into the port of the Air Reservoir. This will help make an airtight seal.
Scrader tire pump valve is shown on the Air Reservoir piece.
Reservoir fitting is shown on the Air Reservoir piece.
The Schrader tire pump fitting and the Reservoir fitting can be screwed firmly into the ports on the ends of the Air Reservoir using a 7/16” wrench.
Preventing Leaks in Cylinder and Valve Fittings
Cylinder Fitting piece.
Flow Meter Fitting piece.
The fittings for pneumatic cylinders include Cylinder fittings and Flow Meters.
Washer is highlighted on a Cylinder Fitting piece.
Washer is highlighted on a Flow Meter Fitting piece.
These fittings have a washer which will help create an airtight seal.
Double Acting Cylinder piece with a Flow Meter attached to one port and a Fitting added to one of the other ports.
Using a small pair of pliers, carefully tighten the fittings to approximately ¼ turn past finger-tight.
Valve Fitting piece.
The pneumatic solenoid valves use valve fittings.
Washer is highlighted on a Valve Fitting piece.
Valve fittings also have washers to create an airtight seal.
Valve Fitting pieces added to ports on the Valve piece.
These fittings also should be tightened ¼ of a turn past finger tight with a pair of small pliers.
Cutting, Inserting, and Releasing Pneumatic Tubing
Diagram indicating that pneumatic tubing pieces should be cut straight across the tubing and not at an angle.
The pneumatic tubing used to connect the pneumatic devices can be cut with a pair of sharp utility shears.
To create an airtight seal, be sure to cut straight across the tubing to create a square end. Do not cut the tubing at an angle.
Note: The longer the length of tubing is between the valve and the pneumatic cylinder, the more air pressure will be lost each time the cylinder is activated.
Reservoir Fitting piece is shown connected to the Air Reservoir.
Arrows indicating that the Reservoir Fitting's outer collar can be pushed down to remove the fitting.
All of the pneumatic tubing fittings accept the tubing by simply inserting the tubing into the fitting until it comes to a stop.
Be sure the pneumatic tubing is fully inserted into the fitting. There is a rubber ring seal the tubing must pass through to create the airtight seal.
To release the tubing the outer collar of the fitting needs to be pushed in towards the fitting and then the tubing can be removed.
Testing For Leaks
Solenoid Valve piece is shown with a bubble icon over one of its Valve Fitting pieces to indicate that bubbles can be detected using soap and water.
If your pneumatic system is not holding air pressure for a period of time, there is an air leak somewhere in the system.
One way to check for an air leak is to apply a small amount of soap and water solution to the areas where the fittings are connected. If bubbles appear at one of these locations, there is an air leak present and the fitting will need to be tightened.
Note: Do not apply soap and water solution to electronic connections.
