Using the Printable VEX GO Parts Ruler
Whether organizing parts, following a set of build instructions, or building a custom design, identifying a part correctly can be crucial to your success.
The VEX GO Parts Ruler is a handy tool to help identify parts.
Note: when printing the .pdf be sure to set to 100% scale.
This article will explain:
Using the Ruler to Identify Parts
The VEX GO Parts Ruler can be used to identify parts while organizing parts or following a set of build instructions. The scale on the ruler is 1:1, so parts can simply be placed on top of the ruler.
Printable VEX GO Parts Ruler measuring the length of an orange beam, showing the orange beam aligned with the ruler.
Measuring Beams and Plates. Example shown is a 2x6 Beam.
  • 2 indicates a width of 2 pitch units.
  • 6 indicates a length of 6 pitch units.
Printable VEX GO Parts Ruler measuring a 0.5-inch yellow standoff
Measuring Standoffs. Example shown is a 0.5x pitch Standoff.
Printable ruler used to measure a 30 mm VEX GO pulley
Measuring Pulleys. Example shown is a 30mm Pulley.
Printable ruler aligned with a 16-tooth VEX GO gear for measuring part size
Measuring Gears. Example shown is a 16 Tooth Gear.
A short rope aligned with the printable VEX GO parts ruler to show its length
Measuring ropes. Example shown is the Short Rope.
  • The Short Rope is 12x pitch
  • The Long Rope is 24x pitch
Printable VEX GO Parts Ruler with the 1x2 Green Pin aligned to show its size.
Measuring Pins. Example shown is a 1x2 Pin.
Printable VEX GO parts ruler with length and angle markings for measuring angle beams components at a 45-degree angle
Measure Specialty Beams. Example shown is a 45° Angle Beam.
Printable VEX GO parts ruler for measuring 2x pitch shafts and other components
Measure Shafts. Example shown is a 2x pitch shaft.
Printable VEX GO parts ruler measuring a rubber shaft collar
Measure shaft accessories. Example shown is a shaft collar.
Tip and trick: The .pdf of the VEX GO Parts Ruler can be printed out on a clear plastic transparency. This will allow the ruler to be overlaid on a robot and measurements can be made by measuring through the ruler.
For more on VEX GO parts, view these articles from the VEX Library.
