You can update your V5 Brain’s firmware in VS Code by connecting with a controller that is tethered to the V5 Brain.
To update the firmware, ensure the controller is tethered to the Brain and a radio is connected to the Brain. Both devices must be powered on to connect them to VS Code.
Without disconnecting the Brain and controller, connect the controller to the computer so it appears in VS Code.
Type >VEX Update into the search bar at the top of the VS Code window.
Select VEX | System: Update Brain vexrobotics.vexcode.system.update.vexos.
A dialog box will open. Select Update to begin updating the Brain's firmware.
The firmware update process will appear at the bottom-right of the screen. Do not unplug the controller or Brain until the update is complete.
Once the firmware update is complete, power cycle the brain.
Once the Brain is reconnected, its firmware number will be updated. To check if your firmware number is up to date, see the V5 Firmware Changelog here.
