The table below lists keyboard shortcuts available while coding in Python within VEXcode GO.
VEXcode Specific
Shortcut | Windows Shortcut | Mac Shortcut |
Start Project | Ctrl + Enter | ⌘ + return |
Step Project | Ctrl + I | ⌘ + I |
Stop Project | Ctrl + E | ⌘ + E |
Save | Ctrl + S | ⌘ + S |
Editing
Copy | Ctrl + C | ⌘ + C |
Copy Line Down | Shift + Alt + DownArrow | Shift + Option + DownArrow |
Copy Line Up | Shift + Alt + UpArrow | Shift + Option + UpArrow |
Cut | Ctrl + X | ⌘ + X |
Delete All Left | (N/A) | ⌘ + Backspace |
Delete All Right | (N/A) | Control + K |
Delete Whole Line | Ctrl + Shift + K | Shift + ⌘ + K |
Join Lines | (N/A) | Control + J |
Paste | Ctrl + V | ⌘ + V |
Redo | Ctrl + Shift + Z | Shift + ⌘ + Z |
Undo | Ctrl + Z | ⌘ + Z |
Autocomplete
Trigger Suggestion | Ctrl + Space | Control + Space |
Commenting
Add Line Comment | Ctrl + K (then) Ctrl + C | ⌘ + K (then) ⌘ + C |
Remove Line Comment | Ctrl + K (then) Ctrl + U | ⌘ + K (then) ⌘ + U |
Toggle Line Comment | Ctrl + / | ⌘ + / |
Cursor and Selection
Add Cursor Above | Ctrl + Alt + UpArrow | Option + ⌘ + UpArrow |
Add Cursor Below | Ctrl + Alt + DownArrow | Option + ⌘ + DownArrow |
Find and Replace
Change All Occurrences | Ctrl + F2 | ⌘ + F2 |
Find | Ctrl + F | ⌘ + F |
Find Next | F3 | ⌘ + G |
Find Previous | Shift + F3 | Shift + ⌘ + G |
Select All Occurrence of Find Match | Ctrl + Shift + L | Shift + ⌘ + L |
Add Selection to Next Find Match | Ctrl + D | ⌘ + D |
Find Next Selection | Ctrl + F3 | ⌘ + F3 |
Find Previous Selection | Ctrl + Shift + F3 | Shift + ⌘ + F3 |
Find With Selection | (N/A) | ⌘ + E |
Zoom in and Out
Editor Font Zoom In (Larger) | Ctrl + DownArrow | ⌘ + DownArrow |
Editor Font Zoom Out (Smaller) | Ctrl + UpArrow | ⌘ + UpArrow |
Line Manipulation
Indent Line | Ctrl + ] | ⌘ + ] |
Insert Line Above | Ctrl + Shift + Enter | Shift + ⌘ + Enter |
Move Line Down | Alt + DownArrow | Option + DownArrow |
Move Line Up | Alt + UpArrow | Option + UpArrow |
Outdent Line | Ctrl + [ | ⌘ + [ |
Navigation
Command Palette | F1 | F1 |
Go to Bracket | Ctrl + Shift + \ | Shift + ⌘ + \ |
Go to Line... | Ctrl + G | Control + G |
Move Caret Left | LeftArrow | LeftArrow |
Move Caret Right | RightArrow | RightArrow |
Show Editor Context Menu | Shift + F10 | Shift + F10 |
Window
Close Window | Alt + F4 | ⌘ + Q |
Select All | Ctrl + A | ⌘ + A |
