Installing VEXcode AIR on Mac
To install VEXcode AIR on a Mac computer, first determine and download the appropriate installer for your system. Follow these steps to identify the correct installer and install VEXcode AIR on your macOS device.
Download the Installer
Close-up of the Apple logo, 'Finder', and 'File' in the macOS menu bar, with the Apple logo highlighted with a red box.
On your Mac computer, select the Apple icon.
macOS menu bar dropdown showing the Apple logo with the 'About This Mac' option highlighted in red.
Select About This Mac from the dropdown menu.
Intel processor
Mac mini information showing a 2018 model with the 'Processor 3.2 GHz 6-Core Intel Core i7' highlighted in red.
Apple Silicon
MacBook Pro information showing a 13-inch, M1, 2020 model with the 'Chip Apple M1' highlighted in red.
Select each image above to enlarge.
  • Intel processor: If your computer says it has an Intel processor, you will need to download the Intel installer.
  • Apple Silicon: If your computer says it has an Apple chip, you will need to download the Apple Silicon installer.
Screenshot of code.vex.com, with the section of Get VEXcode. And a callout box around the VEXcode AIR.
Go to code.vex.com and scroll down to Get VEXcode and select VEXcode AIR >.
A download page for VEXcode AIR version 4.62 with buttons to download for Windows, Mac (Intel), and Mac (Apple Silicon).
If your computer uses an Intel processor, select Download for Mac (Intel).
If your computer uses an Apple chip, select Download for Mac (Apple Silicon).
Install VEXcode AIR
VEXcode AIR Installer shown in the Mac downloads folder
Once you have downloaded the correct installer for your Mac computer, double-click on the installer to begin the installation process.
VEXcode AIR End User License Agreement window with a callout box around the Agree button.
The End User License Agreement will appear. Once you have read through the EULA, select Agree.
VEXcode AIR installation screen with the orange VEXcode AIR icon on the left and the applications window icon in the form of a blue folder on the right, and an arrow in between the two.
Once the installer has finished loading, the installation screen will open.
Click and drag the VEXcode AIR application to the Applications folder.
Dialog box with a callout box around the Replace button.
If a dialog box asks you if you want to replace an existing VEXcode AIR, select Replace.
Mac Applications folder with the orange VEXcode AIR icon called out.
Access your Applications folder and select VEXcode AIR.
A VEXcode AIR workspace showing motion action code blocks on the left and a yellow when started block in the coding area.
Begin working in VEXcode AIR.
