The VEX AIR Drone Controller can be coded using VEXcode AIR which is available as either an app-based or web-based version. To access the web-based VEXcode AIR, follow the steps below.
Web-based VEXcode AIR is available on a Chrome-based browser on Chromebook, Mac, and Window devices.
Navigate to codeAIR.vex.com.
On your first visit, VEXcode AIR will appear with a new blocks project. You can switch to a new Python project, open an example project, or an existing project by opening the File menu.
You can connect your controller to VEXcode AIR using a wired connection to download and run projects.
Follow the steps in this article to use a USB cable to connect your controller to VEXcode AIR.
Now you can get started coding! Use the built-in Tutorials or Help as you get started coding in web-based VEXcode AIR.
