Understanding VEX V5 Wheels
Diagram of various VEX V5 Wheel pieces.
Moving around is a primary function of most robots. Choosing which wheel to use can be a critical decision and can determine the success of a robot’s design; each type of wheel has advantages and disadvantages. The two major factors to consider are the wheel's diameter (the distance from a point on one side of the wheel to a point directly across on the other side) and its traction.
VEX V5 Wheels
This section provides a visual representation of different wheels.
Traction Wheels
These were the original VEX V5 wheels. They are typically used in the center of drivetrains to restrict unwanted sideways movement (such as from defense). Their diameter is set up so one revolution causes the robot to travel an exact distance.
V5 4-inch (320mm Travel) Anti-Static Wheel piece.
The 4'' (320mm Travel) Anti-Static Wheels are the most common wheels used on VEX V5 chassis. The 4'' (320mm travel) wheel pairs well with the 4'' (320mm) Omni-directional Wheel to make a chassis that is consistent and easy to turn.
V5 2.75-inch (220mm Travel) Anti-Static Wheel piece.V5 3.25-inch (260mm Travel) Anti-Static Wheel piece.
The 2.75'' (220mm Travel) Anti-Static Wheel and 3.25'' (260mm Travel) Anti-Static Wheel are good for robots that require lower ground clearance or slower speeds. These are also commonly used for intakes.
Mecanum Wheels
Mecanum wheels incorporate a series of angled rollers that constrain movement to a single axis, granting a drivetrain true omnidirectional capability. It allows the robot not only to move forward and reverse, but also to strafe smoothly without changing its orientation.
V5 V1 2-inch Mecanum Wheel piece.
V1 2'' Mecanum Wheels
V5 V1 4-inch Mecanum Wheel piece.
V1 4'' Mecanum Wheels
V5 V2 2-inch Mecanum Wheel piece.
V2 2'' Mecanum Wheels
Omni-directional Wheels
V5 Omni-directional Wheel pieces.
The Omni-directional Wheels have a series of double-set rollers aligned around the wheel's circumference. This allows the wheels to roll side to side in addition to rolling forward and backward. Omni-directional wheels' rollers allow a robot to turn much easier than rubber tires. These are best used in combination with the 4'' 320mm Traction Wheel (for example, two omni-directional wheels and two traction wheels) to create a chassis that is level and will turn consistently.
Using special orientations of omni-directional wheels allows for more advanced drivetrain designs which can move forward/backward and side to side—omni-directionally!
V5 2.75-inch (220mm Travel) Omni-Directional Anti-Static Wheel piece.
2.75" (220mm Travel) Omni-Directional Anti-Static Wheel
V5 3.25-inch (260mm Travel) Omni-Directional Anti-Static Wheel piece.
3.25" (260mm Travel) Omni-Directional Anti-Static Wheel
Comparison of VEX V5 Wheels
Wheel TypeWheel SizeDistance per RevolutionFootprintGround Clearance
Omni Directional Wheel2.75"220 mm
(8.66 inches)
LargeSmall
3.25"260 mm
(10.24 inches)
MediumMedium
4"320 mm
(12.60 inches)
SmallLarge
Traction Wheels2.75"220 mm
(8.66 inches)
LargeSmall
3.25"260 mm
(10.24 inches)
MediumMedium
4"320 mm
(12.60 inches)
SmallLarge
Mecanum Wheels2"N/ALargeSmall
4"N/ASmallLarge
Diameter
The diameter of a wheel (Hub and Rubber Tire assembly) can affect a number of things.
  • Distance per revolution is the distance a wheel will roll with one complete revolution, as shown in the animation below.
Diagram comparing Small Diameter Wheels and Large Diameter Wheels being used on the side of a robot. Measurements indicate that that smaller wheels have a lower Ground Clearance but the same Footprint size as larger wheels.
Footprint is the area between the points where the robot's outermost wheels touch the ground. Typically, the larger the robot’s footprint, the more stable it is and less likely it is to tip over.
Ground clearance is the height from the ground to the lowest structure on the robot. A larger ground clearance makes it easier for the robot to travel over obstacles.
Traction
The greater the traction of a wheel, the harder the robot can push or pull, and the easier it is for the robot to travel over obstacles. However, if a wheel has a high degree of traction it is also harder for the robot to turn.
