Resetting the One Stick Controller
If the One Stick Controller becomes unresponsive and cannot be turned off normally, pressing the Reset button to force a shutdown, then turning it back on, may help restore normal operation.
Reset the Controller
A One Stick Controller with a glowing yellow light in the center on its back.
To force the controller to power off, insert a thin object (such as a paper clip) into the pinhole and press the Reset button inside.
