Using Web-Based VEXcode AIM
The VEX AIM Coding Robot can be coded using VEXcode AIM which is available as either an app-based or web-based version. To access the web-based VEXcode AIM, follow the steps below.
Web-based VEXcode AIM is available on a Chrome-based browser on Chromebook, Mac, and Window devices.
View of the workspace in VEXcode AIM once the webpage is opened.
Navigate to codeAIM.vex.com.
Top left corner of VEXcode AIM with the file menu opened. A highlight is on the File option in the toolbar, which is the third option from the left.
On your first visit, VEXcode AIM will appear with a new blocks project. You can switch to a new Python project, open an example project, or an existing project by opening the File menu.
Learn more about creating new projects in this article.
Now you can get started coding! Use the built-in Tutorials or Help as you get started coding in web-based VEXcode AIM.
