The VEX VS Code Extension can be used to capture images from the VEX AIM Coding Robot's screen.
Note: The robot must be connected to your computer in order to capture images through VS Code.
Open the VEX Extension while the robot is connected to your computer.
Note: The robot can't connect to the VEX Extension if VEXcode is open.
Under VEX DEVICE INFO, hover over the AIM Robot section header and select the camera icon.
Once you have saved the image using your device's saving dialog, the captured image will appear.
