The VEX AIM Coding Robot can be renamed by using the VS Code Extension.
Note: The robot must be connected to your computer in order to rename it using the VS Code Extension.
Open the VEX Extension while the robot is connected to your computer.
Note: The robot can't connect to the VEX Extension if VEXcode is open.
Under VEX DEVICE INFO, hover over the robot's name and select the pencil icon.
Type a new name for the robot in the text box and press Enter to confirm.
Note: Spaces are not accepted. To separate words, use underscores.
The new name will be set for the robot.
