The Field in the VRC Spin Up Playground in VEXcode VR  has the same dimensions and setup as the Field for an in-person Skills Match in the 2022-2023 VRC Spin Up Competition game. This information can be useful when creating projects in VRC Spin Up for VEXcode VR.
Field Dimensions
Each tile on the Field is 600mm by 600mm (~24 inches by 24 inches).
The Field is six full tiles long.
In total, the Field is 3.65m (~12 feet) long.
The Field is six full tiles wide.
In total, the Field is 3.65m (~12 feet) wide.
Measurement Notes:
Each full tile measurement begins and ends at the edge of the tile.
The total Field measurements begin and end at the inner edge of the Field perimeter.
Field Coordinates
In VRC Spin Up in VEXcode VR, the virtual Hero Bot Disco is equipped with a GPS Sensor that reports its location and angle. The GPS Sensor reports the (X, Y) coordinates of the center of rotation of the robot on the Field, in millimeters or inches. This can be used to code Disco to drive to specific locations, and navigate the VRC Spin Up Field in VEXcode VR using sensor feedback instead of set distances.
The Field in VRC Spin Up in VEXcode VR ranges from approximately -1800mm to 1800mm for the X and Y positions.
The center location, or the origin (0,0), is located in the center of the Field.
Game objects on the VRC Spin Up Field in VEXcode VR are the same size, and in the same location as the field for an in-person Skills Match in the 2022-2023 VRC Spin Up Competition game.
See this article for more information about the location of the game elements on the Field.
See the VRC Spin Up Game Manual for more information about specific game elements.
