The V5 Robot Brain allows your robot to receive a multitude of different inputs, then process those inputs with an abundance of expandable storage that turns the inputs into a wide variety of outputs.
It is the Brain of your robot!
The V5 Robot Brain has a 4.25 inch full color touch-screen which allows you to have direct control with the touch of a finger, in addition, it has a near limitless amount of feedback, a dashboard, and can be customized using VEXcode.
The screen is shielded by a removable plastic protector that is held securely in place by magnets.
Your V5 Robot Brain can be attached to the robot using the four #8-32 threaded inserts located on the bottom of the brain. These can used any of the #8-32 VEX screws.
The Brain also has Pin holes conveniently located on all four sides which will accommodate the included Flanges or can be used with VEX Pins to attach the Robot Brain to your robot.
In addition to a programming and a battery port, the V5 Brain provides 21 Smart Ports which recognize and utilize the V5 Smart Motors, V5 Electromagnet, V5 3-Wire Expander, V5 Radio, and V5 Sensors, as well as allowing for a wired connection to the V5 Controller.
The Brain also has eight 3-Wire ports which can be configured to accept the legacy Servo, the Pneumatic Solenoid Driver, LED’s, and 3-Wire Sensors.
The V5 Robot Brain is fully programmable with VEXcode V5 in Blocks, Python, and C++.
VEXcode V5 is available for all popular devices.
The V5 Brain has eight slots to store eight different custom programs for selection and use.
For advanced programmers, VEXcode Pro V5 (C++) is also available.
There are also a number of other custom programming options available.
Robot Brain Specifications
| V5 Robot Brain Specifications | |
| Motor Ports | Any of the 21 Smart Ports |
| Smart Sensor Ports | Any of the 21 Smart Ports |
| Radio Ports | Any of the 21 Smart Ports |
| Tether Ports | Any of the 21 Smart Ports |
| Digital Ports | Any of the 8 built-in 3-Wire Ports |
| Analog Ports | Any of the 8 built-in 3-Wire Ports |
| 3-Wire Expansion | Add 8 more ports using a 3-Wire Expander. The 3-Wire Expander uses one Smart Port. |
| VEXos Processor | One Cortex A9 at 667 MHz Two Cortex M0 at 32 MHz each One FPGA |
| User Processor | One Cortex A9 1333 Million Instructions per second |
| RAM | 128 MB |
| Flash | 32 MB |
| User Program Slots | 8 |
| USB | 2.0 High Speed (480 Mbit/s) |
| Color Touch Screen | 4.25", 480 x 272 pixels, 65k colors |
| Expansion | up to 16 GB, FAT32 |
| Wireless | VEXnet 3.0 and Bluetooth 4.2 |
| System Voltage | 12.8 v |
| Size | 4.0" W x 5.5" H x 1.3" L (101.6 mm x 139.7 mm x 33.02 mm) |
| Weight | 0.63 lbs (285g) |
For more information on the V5 Robot Brain please see these articles.
