The V5 Robot Battery Li-Ion 1100mAh will provide you consistent performance every time you power up your robot.
This Lithium Iron Phosphate (LiFePO4) battery is equipped with circuitry and control to allow for higher sustained power and more reliable function.
The V5 System as a whole is designed to produce identical motor performance at any battery charge level.
Your V5 Robot Battery can be firmly attached to your robot with a set of Battery Clips and solidly connected to the V5 Brain with the V5 Power Cable which has locking clips on both ends.
Longer lengths of the V5 Power Cable are available.
The V5 Battery has a push button which will activate four LEDs and indicate the status of the battery.
The LEDs will also provide a visual reference while the battery is charging.
V5 Battery Specifications
| V5 Robot Battery Specifications | |
| Battery Chemistry | Lithium Iron (LiFePO4) |
| Approximate Lifespan | 2000 full recharge cycles |
| Nominal Voltage | 12.8 Volts |
| Maximum Current | 20 Amps |
| Maximum Output Power | 256 Watts |
| # Motors at Peak Power | 10 |
| Low Battery Performance |
Motors output 100% power |
| Capacity | 12.8 Wh |
| Weight | 0.77 lbs (350g) |
| Dimensions | 1.82" W x 6.31" L x 1.18" H (46.45mm W x 160.45mm L x 30.33mm H) |
For more information on the V5 Battery, please see these articles.
