The VEX IQ Competition (VIQC) Virtual Skills Field has the same dimensions and setup as the Field for an in-person Skills Match. This information can be useful when coding this season's Hero Bot, in VIQC Virtual Skills.
Each image shows the full 6 foot by 8 foot Field used with VIQC Virtual Skills. Select each image to expand.
Field Dimensions
Each full tile on the Field is 300mm by 300mm (~12 inches by 12 inches).
Each half tile on the Field is 150mm by 300mm (~6 inches by 12 inches).
The corner tiles on the Field are 150mm by 150mm (~6 inches by 6 inches).
The Field is five full tiles, and two half-tiles long.
In total, the Field is 1.8m (~6 feet) long.
The Field is seven full tiles, and two half-tiles wide.
In total, the Field is 2.4m (~8 feet) wide.
Measurement Notes
- Each full tile measurement begins and ends at the center of the black line.
- Each partial tile measurement begins at the center of the black line and ends at the inner edge of the wall.
- The total Field measurements begin and end at the inner edge of the walls.
