Building with VEX IQ Motor Groups
When building a custom VEX IQ Robot, sometimes you just need more power. One easy way to do this is to add another motor. These two motors working together are known as a motor group.
How motor groups are mechanically tied together
In order for two motors to work together they need to be mechanically connected in some manner.
Some methods of connecting motors together mechanically include:
Both motors share the same parallel drive shaft, working together to provide a consistent and higher power output. By sharing the drive shaft, the combined torque and power from both motors is effectively utilized, leading to increased power output, consistent performance. This 3D Build offers a detailed look at two motors sharing the same parallel drive shaft.
Both motors share the same gear set, providing enhanced speed. Despite sharing the same gear set, each motor can be adjusted independently for increased control and precision of movement. Two motors attached to one gear set increases the torque, enabling the robot to more easily perform tasks such as heavy lifting. This 3D Build offers a detailed look at two motors sharing the same gear set.
Both motors share the same chain and sprocket system, enabling the robot to transfer torque more easily. This configuration also provides more stability and lowers friction, which enables high mechanical efficiency. This design is also more compact, allowing fore a more streamlined and efficient design as well as increased flexibility. This 3D Build offers a detailed look at two motors sharing the same chain and sprocket system.
Both motors have wheels on the same side of the drivetrain. This principle is demonstrated in this 3D Build.
The importance of motor spin direction
When two motors are working together it is very important that the direction each motor is spinning do not fight with one another. The orientation of the motors to one another will determine which direction each will need to spin. A typical robot arm with two motors working together to lift the arm is an example of how this works.
In this case, the driven gear attached to the right side of the arm will need to rotate counterclockwise for the arm to lift. Since the driving gear needs to rotate in the opposite direction of the driven gear on the arm, the right motor of the arm will need to spin the smaller driving gear in a clockwise direction. This 3D Build offers a detailed look at two motors that should rotate in opposite directions to power a robot arm.
However, on the left side of the arm the driven gear will need to rotate in the opposite direction or clockwise. This also means the left motor will need to spin in the opposite counterclockwise direction.
Diagram of a swing arm with the opposite rotations of its two motors highlighted. Text reads Left driven gear, clockwise.
As a general rule, if the two motors in a motor group are facing each other as in the application with the arm above, the spin of one motor in the motor group will need to be reversed so the motors do not fight against one another. This 3D Build offers a detailed look at two motors that should rotate in opposite directions.
If the motors are facing in the same direction, then both motors in the motor group will need to spin in the same direction. This principle is demonstrated in this 3D Build.
When using VEXcode IQ, it is very easy to reverse a motor within a motor group. This can be done when you are adding the motor group as a device.
VEXcode IQ Devices Motor Group menu after the Motor ports have been selected. There are options to change each motor's drive direction, and the option to reverse the second motor has been selected and is highlighted.
For more information on configuring a motor group in VEXcode IQ, view this article from the VEX Library.
Applications in which motor groups will be helpful
The principles of mechanical advantage tell us whenever:
  • More weight needs to be lifted.
  • More distance needs to be traveled.
  • More speed is needed.
  • More force will be needed.
These principles can be seen with robot arm as well as drivetrains.
Robot arms
A single swing arm may be able to lift light things with a single motor. However, if the arm needs to lift a heavy object, a second motor may be necessary. The 3D Build below offers a detailed look at one motor that is powering a swing arm.
The 3D Build below offers a detailed look at two motors that are powering a double reverse four bar arm.
When designing advanced arms such as a six-bar or a double-reverse four bar, two motors will be required. This is because these arms are capable of lifting objects higher and faster. The 3D Build below offers a detailed look at two motors that are powering a six bar arm.
Drivetrains
When designing a drivetrain you may want to go faster, climb steeper, or push more with your robot. A four motor drivetrain will allow you to accomplish this. This 3D Build offers a detailed look at a drivetrain with four motors and four wheels.
Screenshot of the Drivetrain 4-motor option in the VEXcode IQ Add a Device menu.
VEXcode IQ has a DRIVETRAIN 4-motor device which will allow you to program your drivetrain.
For more information on configuring a 4-Motor Drivetrain, view this article from the VEX Library.
However, a 4-Motor Drivetrain device limits your robot turns to pivot turns. If your robot navigation requires different turns, motor groups can allow these.
Using Motor Groups for different types of turns
A skid-steer robot is a robot which turns by adjusting the speed and direction of the drive wheels on each side of the robot. The types of turns are:
Top down view of a 4-motor Drivetrain build with a circle and a point that represent its center of rotation when performing a pivot turn. The center of rotation is directly in the center of the 4 motors.VEXcode IQ Blocks project that reads When Started, spin LeftDriveMotors forward and then spin RightDriveMotors reverse.
Pivot turns: this type of turn pivots on a center point between the drive wheels. This happens when the drive wheel/wheels on one side of the robot move in reverse to the drive wheel/wheels on the other side of the robot. This type of turn is helpful when the robot needs to turn in place.
Top down view of a 4-motor Drivetrain build with a circle and a point that represent its center of rotation when performing a drag turn. The center of rotation is in between the motors on the right, directly opposite the spinning motors on the left.VEXcode IQ Blocks project that reads When Started, spin LeftDriveMotors forward.
Drag turns: this type of turn has the pivot point on the side of the robot. This happens when the drive wheel/wheels on one side of the robot move forward or reverse and the drive wheel/wheels on the other side of the robot do not move. This type of turn can be helpful when lining up with a game piece.
Top down view of a 4-motor Drivetrain build with a circle and a point that represent its center of rotation when performing an arc turn. The center of rotation is far to the right of the robot and not in between any set of motors.VEXcode IQ Blocks project that reads When Started, set LeftDriveMotors velocity to 50% and then set RightDriveMotors velocity to 25%. Next, spin LeftDriveMotors forward and then spin RightDriveMotors forward.
Arc turns: this type of turn has the pivot point located outside of the drivetrain of the robot. This happens when the drive wheel/wheels on one side of the robot spin at a faster or slower speed than the drive wheel/wheels on the other side of the robot. This type of turn allows for a shorter travel distance when navigating around obstacles.
