VEX 123 can be used in a wide variety of learning environments, by educators and students with various teaching styles and needs. The following printable materials can be used to support differentiation and various implementations of VEX 123, including remote learning, that arise throughout the year.
You can print the PDFs below to use in your setting however you see fit.
Printable small touch buttons
Cut these touch button symbols out, and use them to help plan and build projects using the touch interface.
Printable large touch buttons
Cut these touch button symbols out and use them to help plan and build projects using the touch interface. The larger size makes them ideal for demonstrations, or project planning for whole group instruction.
Color-in project sheet with touch buttons
Color in a sequence of touch button presses to plan or save a project.
Fill-in Coder sheet
Write or draw the Coder cards in a project to plan or save a Coder card project.
Draw-on motion planning sheet
Use this blank image of the 123 Field to plan the motion of the 123 Robot in a project.
Fill-in project and motion planning sheet for touch buttons
Use this sheet to color-in the touch button sequence in a project, and plan the motion of the 123 Robot together.
Fill-in project and motion planning sheet for the Coder
Use this sheet to write or draw the Coder cards in a project, and plan the motion of the 123 Robot together.
