VEX 123 can be used in a wide variety of learning environments, by educators and students with various teaching styles and needs. The following printable materials can be used to support differentiation and various implementations of VEX 123, including remote learning, that arise throughout the year.
You can print the PDFs below to use in your setting however you see fit.
Printable small touch buttons
Small Touch Buttons
Small Touch Buttons PDF Printable featuring small icons of the 123 Robot's 4 touch buttons.
Cut these touch button symbols out, and use them to help plan and build projects using the touch interface.
Printable large touch buttons
Large touch buttons - Page 1
Large Touch Buttons Page 1 PDF Printable featuring two large icons of the 123 Robot's Move and Turn Left touch buttons.
Large touch buttons - Page 2
Large Touch Buttons Page 2 PDF Printable featuring two large icons of the 123 Robot's Turn Right and Play Sound touch buttons.
Large touch buttons - One page
Large Touch Buttons One Page PDF Printable featuring four large icons, one for each of the 123 Robot's 4 touch buttons.
Cut these touch button symbols out and use them to help plan and build projects using the touch interface. The larger size makes them ideal for demonstrations, or project planning for whole group instruction.
Color-in project sheet with touch buttons
Project Plan Worksheet
Project Plan Worksheet PDF Printable featuring 10 rows of touch commands that can be used to plan and save a project.
Color in a sequence of touch button presses to plan or save a project.
Fill-in Coder sheet
Blank Coder Worksheet
Blank Coder Worksheet PDF Printable featuring 10 rows of blank commands that can be used to plan and save a project.
Write or draw the Coder cards in a project to plan or save a Coder card project.
Draw-on motion planning sheet
Motion Planning Worksheet
Motion Planning Worksheet PDF Printable featuring a top-down view of a 2 by 2 123 Field that can be used to plan the robot's motion.
Use this blank image of the 123 Field to plan the motion of the 123 Robot in a project.
Fill-in project and motion planning sheet for touch buttons
Touch and Motion Planning Worksheet
Touch and Motion Planning Worksheet PDF Printable, featuring 10 rows of touch command bubbles next to a top-down view of a 123 Field that can be used to plan the robot's motion.
Use this sheet to color-in the touch button sequence in a project, and plan the motion of the 123 Robot together.
Fill-in project and motion planning sheet for the Coder
Project and Motion Planning Worksheet
Project and Motion Planning Worksheet PDF Printable, featuring 10 blank rows to write touch commands next to a top-down view of a 123 Field that can be used to plan the robot's motion.
Use this sheet to write or draw the Coder cards in a project, and plan the motion of the 123 Robot together.
Side-by-Side Touch Buttons and Coder Planning Sheet
Side by Side Planning Worksheet
Side by Side Planning Worksheet PDF Printable, featuring 10 rows of touch command bubbles next to 10 blank rows to write touch commands.
Use this sheet to plan a project using touch buttons and then transition it to a Coder project by connecting each touch button command to a corresponding Coder card.
Printable Coder Cards
Coder Cards Printables
Coder Cards PDF Printable, featuring two pages that contains one of each 123 Coder card.
Cut these Coder Card images out and use them to help plan, build, and debug projects using the Coder. They can be used in conjunction with the Fill-in Coder sheet or the Fill-in project and motion planning sheet for the Coder, or on their own.
Art Ring Canvas
Art Ring Canvas
(US Letter)
Art Ring Canvas (US Letter) PDF Printable, featuring three Art Ring Canvas templates.
Art Ring Alternative Canvas
(US Letter)
Art Ring Alternative Canvas (US Letter) PDF Printable, featuring three Art Ring Alternative Canvas templates.
Art Ring Canvas
(International A4)
Art Ring Canvas (International A4) PDF Printable, featuring three Art Ring Canvas templates.
(International A4)
Art Ring Alternative Canvas (International A4) PDF Printable, featuring three Art Ring Alternative Canvas templates.
The Art Ring Canvas is a template that is designed to fit into the slots on the Art Ring. When cut out, the Art Ring Canvas can be taped together in the back, and will fit into the slots on the Art Ring, to sit atop your 123 Robot – turning it into any character or object you wish. Art Ring Canvases can be printed and drawn on, or decorated with other craft materials. Cut along the solid lines, and use the dotted lines as indicators of where the drawing space ends.
Printable Full Size 2x2 Field
Full Size 2x2 Field (A1)
Full Size 2x2 Field (A1) PDF Printable featuring a top-down view of a 2 by 2 123 Field that can be used to plan the robot's motion.
Print this VEX 123 Field to use with your 123 Robots, the same way you would use the 123 Field. This field is A1 size (33.1 x 23.4 inches) and can be printed to create a supplemental Field, or to use as a teaching tool with your students.
123 Printable Certificates
123 Blank Student Certificate
Blank Student Certificate PDF Printable featuring a blank 123 Certificate with spaces for a signature and a student's name.
Use this blank VEX 123 Certificate of Completion whenever you need to customize your own certificate to celebrate students’ success with VEX 123.
