Using Comments in VEXcode 123
Comments are usually added to projects to explain a programmer's intentions. They are helpful when collaborating and troubleshooting.
Drag a [Comment] block and attach it to any block in a stack.
VEXcode workspace showing a Comment block being dragged from the Toolbox and into a stack of blocks.
Type any text, numbers, or symbols into the [Comment] block.
VEXcode project with a Comment block that has a highlighted text field and reads 'Add text, numbers, or symbols here'.
When you finish the comment, click anywhere outside of the [Comment] block, or press 'Return' to finish editing the comment.
VEXcode project with a Comment block that has a saved message in its text field that reads 'Add text, numbers, or symbols here'.
Note: The inside of the [Comment] block will turn from white to gray when finished.
