Deleting Blocks in VEXcode 123
Blocks in VEXcode 123 can be deleted in a number of ways.
Drag to Delete
Select a block or a stack of blocks in the Workspace and drag them left to the Toolbox to delete from your project.
VEXcode 123 application workspace with a block being dragged back into the Toolbox to delete it.
Delete a Single Block from a Stack
To remove a single block from a stack, context-select (right click or long press) a block in a stack and then choose 'Delete Block' from the context menu. This will also delete any nested blocks if a block with parameters is chosen to be deleted.
VEXcode 123 application workspace with a block's context menu opened and the Delete Block option highlighted.
Delete All Blocks
To remove all of the blocks in the Workspace, context-select (right click or long press) the background of the Workspace and choose 'Delete X Blocks.'
VEXcode 123 application workspace with the background's context menu opened and the Delete X blocks option highlighted. This option will delete all blocks in the workspace.
When choosing to delete more than one block, you will be asked to confirm deleting all blocks to prevent accidental deletion. A prompt will NOT appear when nested blocks are selected to be deleted.
VEXcode 123 application workspace after the Delete X blocks option has been selected. A prompt reads Delete all X blocks? The user can press Cancel or Ok.
Note: Choosing this option will not delete the {When started} block.
