Viewing Tutorial Videos in VEXcode 123
Tutorial videos are a great resource if you are just getting started with VEXcode 123. They cover specific functionalities of VEXcode 123, as well as coding concepts.
Viewing a Tutorial Video
VEXcode 123 Toolbar with the Tutorials icon highlighted to the right of the File menu icon.
To view a video, select ‘TUTORIALS’ from the Toolbar.
Note: the tutorial video window may be open when VEXcode 123 launches.
Thumbnail for the Getting Started tutorial video in VEXcode 123.
As an example, select the ‘Getting Started’ tutorial video.
Getting Started tutorial video is open, and the play video icon on the bottom left is highlighted.
Select the play icon on the video window to start the video.
Getting Started tutorial video is open, and the Tutorials icon in the top left corner is highlighted.
You can get back to the tutorials from the ‘Tutorials’ icon in the top left of the window.
Getting Started tutorial video is open, and the Shrink icon in the top right is highlighted.
You can shrink the window.
Getting Started tutorial video is open and shrunk. There is an Expand icon where the Shrink icon used to be.
If the window was shrunk, you can ‘Expand’ the window.
Getting Started tutorial video is open, and the Close icon in the top right corner is highlighted.
You can close the window at any time.
Getting Started tutorial video is open and playing, and the pause video icon on the bottom left is highlighted.
You can pause the video at any time by selecting the pause icon.
Getting Started tutorial video is open, and the fullscreen icon on the bottom right is highlighted.
You can expand to full screen.
Prompt that appears after opening a video in fullscreen that reads Press escape to exit full screen.
To revert from full screen:
  • Select ‘esc’ on a keyboard.
Getting Started tutorial video is open and in fullscreen, and there is an exit fullscreen icon where the fullscreen icon used to be.
  • Select the collapse icon in the bottom right corner.
Getting Started tutorial video is open and in fullscreen on a tablet, and there is an exit fullscreen icon in the top left corner that is highlighted.
  • Press ‘X’ on a tablet.
