Accessing Help in VEXcode 123
Help explains what a block does so that you can figure out if it’s helpful for your project.
Select the Help icon. It’s at the top right of the interface and has a question mark in it.
VEXcode 123 Toolbar with the Help icon highlighted to the right of the Monitor Console icon.
You will see a blank screen extend from the right until you select a block to learn more about it.
VEXcode 123 with the Help menu opened and no block selected. The Help menu has a message that reads 'Select a block to see more information'.
Select any blocks that you want to learn more about.
VEXcode 123 with the Help menu opened and the Drive block selected. Descriptions of the block and how it can be used are shown along with images of example uses.
Hide the Help menu when finished by selecting the right arrow next to the Help icon.
VEXcode 123 with the Help menu opened and the Close Menu arrow on the right side highlighted.
